Seibert74
- Brooklyn Park, MN
- SX192
Good afternoon everyone,
As I was winterizing mt SX192 just now, I pulled my pump to grease the driveshaft splines. I noticed that the spline end was very discolored compared to the impeller end of the shaft. As can be seen in the photos, the driveshaft is purple and blue, which I assume is from high heat and friction. Is this normal or do I have a bearing issue? I also noticed an etching on the shaft where it rides on a bearing.
