Marcio Fazzio Martins
Need help!
Engine mounts broke and engine moved forward.
Since the bearings do not sound good I decided to change the intermediate shaft housing.
I removed the engine to make it easy to change the mounts.
When removing the pump unit, the shaft moved a little bit and got stuck. After hammering around while pulling with an engine lifter attached to a tree it moved another inch and stopped.
Intermediate shaft is also stuck. By looking at the Service Manual, it seems that the only place it could be stuck is the male/female connection between the 2 shafts where the splines either have rust or they were damaged when the engine was running unaligned after the engine mounts gave up.
Any suggestions before considering cutting the shaft?
Would really appreciate some help.
Thanks!!!
Thanks!!!
