UnfixedPyle
- 212X
I've noticed when I have had 10 people or now with transom ballast the e-series speed control doesn't like to get to it's set speed if that speed is 10-11 mph. It hangs up at 8-9. This isn't good for surfing because 10-11 is the sweet spot. To compensate I've been setting higher speeds, 13.5 gets me right between 10-11. It appears that the e-series doesn't want to go above a certain rpm (right around 6k). Without a fully loaded boat it hits the speed just fine, but not when maxing out the weight limit. Anyone else experience this? Have a "fix"?
