What's wrong with them?Were are the ecu boxes installed on a 2007 yamaha ar230 mr1 ho boat
Sorry to revive an old thread but it seems I may be in need of an ecu... @Ronnie what was it u mentioned about sending it in to somewhere to have it repaired?Switch the ecus between your engines if you verify that you have a bad one co snider sending it in to carmo for possible repair at a cost of about $300 otherwise buy a new one for $1,100ish. Some,times I see used ones online for $600 or so but I wouldn't buy one them unless it came with a money back guarantee.
where did u send your injectors?I had my injectors clean and tested when I sent my ecu off . Also try carmo they can repair them
I used to be big into rotary engined cars. For some reason Mazda couldn't make a "non-leaky" injector for a few years. There is a local place I always took my injectors. Name and contact is below. They would always flow, leak, and electrical test them for me for like $30/injector or something like that. Took them a batch of 10 once, and picked the 4 closest in flow to put into a car I was tuning. Worked like a champ and was one of the easiest tunes I've done.where did u send your injectors?
Keep in mind that injectors that cause high resistance in the ECU will eventually kill the new ECU.Thanks. I still have not even gone to look at the boat yet.. Lol.. I'm gonna start messing with it this evening some. If I don't have to keas with the injectors I'm not going to but if there is any indications its more than an ecu then I am gonna look into that as well. Pulling injectors is a little more iblnvolved than I am comfortable with. But I may have to learn!
This is exactly correct. The driver circuitry in the ECU is typically somewhat sensitive to injector resistance in general.Keep in mind that injectors that cause high resistance in the ECU will eventually kill the new ECU.
You should be able to leave it installed. Remove the connector. Measure resistance across the inputs. Record value and compare to acceptable value from service manual. Should be a quick and easy check.Now I am going to have to research how to check the resistance of the injectors. I know injector one is where the problem is now.. Not sure if that is what was the cause..
