Canuckjetboater
- SX195
I looked through our FAQ and Search functions (both superb) and followed a link to another forum (the one that is not to be mentioned LOL). On it were discussions of intentions to use the low engine drain plug to install a hose/line to remove oil. I am interested to know if any forum member has done this. Yes, our engines run in a cleaner environment, at RPMs well below their danger point and for lower hours. BUT - they still work hard and I do not like leaving as much oil as a dipstick removal system leaves behind. On every boat I have owned I have installed a "cross notched" brass fitting in the oil pan with an oil resistant hose connected to a 12v pump. Oil change - heat the engine to operating temperature to remove acids, water vapors and contaminants, then flip the switch and sip a beer while all the hot messy oil is pumped into a jug. While I'm at it has anyone installed a remote oil filter set-up for their engine? These are two mods I am considering. ![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
