ScarabMike
- Green Cove Springs, FL
- Scarab
- HO Impulse
I hope this information was passed to everyone when buying their boats. But, I feel as if we have to cover it in its own thread.
When flushing a rotax powered craft, try your best not to go over 2 minutes. There is a ring that seals the drive shaft of the pump to the engine called the "carbon seal".
This ring uses contact with the water within the shaft tube to cool itself. It is a wear item, and if it gets too hot, it will prematurely fail. When you flush your engine, it does not squirt water on this seal.
A carbon ring that doesn't seal correctly can sink a boat in SECONDS.
Another issue with these seals is a misaligned engine/pump. This happens when the company does not take precaution to place the new engine correctly from factory, or a replacement engine.
Signs of a miss-aligned engine and pump other than carbon seal issues, is impeller nose cones that won't stay in place, excessive wear on a brand new wear ring, pto seal oil leaks, and slight vibration.
Here is a picture of a misaligned engine/pump.
Here is a video of a carbon seal starting to wear, and in need of replacing.
Some folks have also noticed that the water that comes into the boat will be hot. This heat is caused by the friction on the seal/shaft connection.
