Engine flush/Carbon Seal Issues
ScarabMike
Green Cove Springs, FL
I hope this information was passed to everyone when buying their boats. But, I feel as if we have to cover it in its own thread.
When flushing a rotax powered craft, try your best not to go over 2 minutes. There is a ring that seals the drive shaft of the pump to the engine called the "carbon seal".
This ring uses contact with the water within the shaft tube to cool itself. It is a wear item, and if it gets too hot, it will prematurely fail. When you flush your engine, it does not squirt water on this seal.
A carbon ring that doesn't seal correctly can sink a boat in SECONDS.
Another issue with these seals is a misaligned engine/pump. This happens when the company does not take precaution to place the new engine correctly from factory, or a replacement engine.
Signs of a miss-aligned engine and pump other than carbon seal issues, is impeller nose cones that won't stay in place, excessive wear on a brand new wear ring, pto seal oil leaks, and slight vibration.
Here is a picture of a misaligned engine/pump.
Here is a video of a carbon seal starting to wear, and in need of replacing.
Some folks have also noticed that the water that comes into the boat will be hot. This heat is caused by the friction on the seal/shaft connection.
Chapvrx
New Jersey
Chaparral
VRX
Thank You for posting this @ScarabMike it looks like the problem that just happened to my Chapparel Vortex VRX , I get lots of water true this particular spot in my bilge and the bilge pump is draining every 1-2 min from my boat I can see and hear water leaking in , how difficult is it to do it yourself ? it looks like impossible to find a dealer that's willing to work on my new boat:( right now they all booked up and I have a boat trip lined up on July 1st, can you recommend a shop that will be able to fix carbon seal I am willing to drive
ScarabMike
The carbon ring isn't to hard to change if you take your time, and have a friend to help. The hardest part is getting to it as it's under a bunch of pipes, and hoses. Pulling the pump, and impeller is not too hard.
If you go that route, use this seal setup. It is 5mm thicker than oem. This puts a little more pressure on the carbon ring which causes less wear, and makes a better seal.
https://www.4-tecperformance.com/index.php?main_page=product_info&cPath=18_15&products_id=4858
Make sure you check your clamp, the teeth or ribs may be broken, and check your rubber boot bellow for dry rot, cracks, or tears.
Chapvrx
New Jersey
Chaparral
VRX
Thanks Mike @ScarabMike this really helps , now do you know where is a good place to source new rubber boot to change,just in case , and do I need to put new /more grease in there?
Also I think this info should be posted in chaparral section of this forum to warn and inform those owners , that prolonged engine flashing could cause unnecessary damage to this part of your boat, and also if something gets stock, and you loose power and or you get cavitation, its better to shot that engine down, CLOSE the water valve to that engine, and limp back to the ramp and your trailer to clear the abstraction from the pump , because if your engine is not getting enough water you will damage this part in few minutes by trying to unclog your pump,
There is a lot of misconceptions with this boats and new owners, that nothing will get stock there , and if something get stock don't worry it will shred and spit it out, Do Not Risk It,get your boat out
Jpseph296
long beach island nj
Scarab
HO Impulse
Will this seal work for 2014 scarab 195hoi
Robo
Pa
If taken care of what is the life span of a carbon ring?
255IDTwin300s
Orlando Area
Scarab
Wake
I have had about 15 4-tec Jet ski's . All rxp-X's with S/C engines from 215, 255, and 300's.. I have had 2 skis that were from 2005 and 2006 - and I went jumping with them in Sebastian where I probably jumped them well over 500 jumps each, some well over 20 ft in the air, out of all the ski's I have had - I have never had a carbon ring go bad. Hopefully I didn't just jinx my self there but that is the case. My ski's have all been modified with larger s/c's, impeller pitch changes, tuning, etc.. I know of one guy I used to ride with that had a carbon seal go out and we had to tow him in quickly on a river ride as it will take on a shitload of water quickly.
Robo
Pa
Thank you i bought a rxt 260 last year with 200 hrs and was wondering if i should change it for precaution or leave it
Beachbummer
Houston TX
In the Sea doos from the 90s the rings were a liitle smaller. I replaced one after 400 hours because it looked smaller than before. If everything is aligned properly it lasts for a long time.
The pressure of the bellows on the stainless floating ring is what seals the water out... If you want to see something scary, push the Bellow by hand back to open the seal while in the water...BAM... You can see the influx of water right through. That's the water that cools the seal, and that's all that keeping the water out.
Aside, but worth noting...A bilge alarm is so useful in letting you know early on that something is not right. It's a matter of time available to figure things out before you sink... If you find out there is a hole on the boat because you are standing on water, you lose the game. (Game being, return home safe and happy)
If you notice early on and use a plastic bag to keep the water out, winner winner.
Thin layers of rubber hose separate us from the bottom of the Sea in inboard boats. Forewarned is forearmed.
Need A Vacation
Mid-Mi
Scarab
215 ID
Is it possible if the hose was tee’d and set up a hose to spray water up into the shaft/seal area, would this help prevent any seal issues?
Just a thought... Trying to figure out an easy way for oil changes down the road without being at the lake.
BuckInNC
Topsail Beach NC
Scarab
255 Open ID
Yikes!! Have a new 255 Open ID with about 2 hours on the engines. Engine temp light came on so I took it back to the dealer. He found a coolant leak because a hose fitting was not properly tightened. He tightened it up, added coolant and then just to make sure all was well he emailed me: "We ran on the hose again for 20ish minutes and watched the cooling system cycle with the computer." And also, "We are going to hose run it one more time but I think we’ve got it ironed out for you." Sounds to me like that probably wrecked the seal. Unless there is some way to provide cooling to the heat exchangers while the boat is on the trailer. I do not have it back yet but I am very concerned that I will now have a really big problem. Am I right to be concerned?
Thanks for any ideas or suggestions.
BobJohnson
Highland Park, il
Chaparral
VR
@BuckInNC Yes, be concerned. They might ave a tank they can put it in, but the way he worded it with on hose, sounds scary as hell. Please let us know what you find!
BuckInNC
Topsail Beach NC
Scarab
255 Open ID
Thanks a lot for the advice.
Spoke with the dealer late yesterday afternoon. And asked specifically how they do the hose test. He described the flush process as stated in the manual; start engine, turn on the water, turn off the water, stop engine. But, importantly, never mentioned the do not exceed 2 minutes warning. And they obviously went way beyond that on at least 3 occasions, maybe more. This is a long time Yamaha dealer and just picked up Scarab. And I think they are not aware of what they have done. The boat has not been in the water since they began to deal with the coolant leak. So, my real question is, how is this going to manifest itself? Sounds to me like the next time we launch it is likely to go straight to the bottom as described by ScarabMike at the top of the thread. Or if not then, sometime very soon thereafter. Obviously still under warranty, but that is really no consolation. I'm thinking I should try to return the boat and start all over.
Thanks a lot for the reply that confirmed my worst fears. Let you know how it works out.
Dean P
Chaparral
VRX
There's a lot to be said in "When you don't know, you don't know." Obviously they don't know what they're doing. But, on the other hand, I would assume alarms should have been going off as the temps would trigger this? They may have stretched the truth a little.
BuckInNC
Topsail Beach NC
Scarab
255 Open ID
Thanks for the thoughts.
Just to make sure I understand your point. Is there a temp sensor on the seal that would have activated if the seal was run too long and got hot enough to damage it? Have not found anything about that. My real concern is that the seal did overheat but they are not aware of that. I'm going on the assumption that you discover the problem when it begins leaking. They ran it long enough for the engine thermostat to cycle open and close and the engine overheat alarm never came on. But I am not sure how an overheated seal would register.
Thanks - I'll post any updates.
Dean P
Chaparral
VRX
Our boats these days have alarms for just about everything. I do not know if there is one for the seal ( I have not had this issue) but if everything were to overheat a fault code/alarm would have been activated. Do you have any fault codes?
Beachbummer
Houston TX
One way to mitigate this while flushing is to spray the ring. They did not do this. It is possible this will manifest itself in shorter Carbon Ring Life. It's hard to know. This was a one time kind of event. Asking for replacement of wear ring at this point may be premature, but if you ask and they do it, great. Document with them what they told you first, and then show them what the manual says about the flush length. See what they offer...
What I highly recommend regardless on how you resolve this is to add a bilge alarm. If you don't know there is a leak it's very hard to find it until it's too late. If you see the wear ring destroyed while at sea you can probably save the boat with a plastic bag with your head in the engine compartment, but ONLY if you know there is a leak and there is enough time to act.
Best of luck! I had a boat with a wear ring for 14 years and it was a lot of fun. Enjoy the boat!
BuckInNC
Topsail Beach NC
Scarab
255 Open ID
Thanks for the comments and suggestions.
There were no engine faults, alarms, etc. Everything appeared normal during the several dry runs, particularly the engine temp, for a total of more than an hour on the hose. So, I guess there is not a sensor or alarm associated with the seal. Basically I think the seal here is the equivalent to the prop shaft seal on an outboard or stuffing box on an inboard. But a failed seal on an outboard will not sink the boat. And I know that you sure do not let the wheels turn for very long while on the hard. Anyhow, I'm have a call into the dealer and will ask him to replace the seal. Even if it not completely shot now it sure has had a lot of wear put on it for only about 3-4 hours of total engine time. And likely to fail at any time. Will be spending a lot of time with grand kids and family in the new boat and just not willing to put all of that at risk. I know the seal is designed to wear but for all I know it is now 95% used up. Kind of like getting a new car and the disk pads are already down to 3 mm. Should not have to deal with this on a brand new vessel I'll let you know as thing develop.
Rick215HO
Houston, TX
Scarab
HO Impulse
Great information and post. That is unlikely known by anyone that has not read the manual (unfortunately including the techs). When I bought the second Scarab (255HO) new from the dealer I let the "Captain" at the dealer run through the entire orientation of the boat (to see if there was anything new to learn), when they got to the engine flushing part, they ran the engines with the flushing water forever "to make sure it was flushed good" and I had to stop them at 215F+ engine temp, they actually didn't know the boat had to be in the water to cool the engines (flushing does not cool engines) and most certainly had no idea about what a carbon seal was (hope it has changed, but dealers had no idea what they were selling back then in '17). That brings me to a question worthy of a thread itself... Water cooling for the carbon ring? at WOT doing 50+ MPH I doubt there is any water in the hull cavity where the seal is (any thoughts on this?). Misalignment and motor mount failure would seem the more likely culprits as you mention... I have hundreds of hours between the two Scarabs I have owned and never had a seal issue but obviously there seems to be something going on out there.
