I’m not the original owner it is in saltwater .the plug looked real clean that I swapped. So the good engine now says check engine and the bad engine still says overheatSo now both engines are throwing a code at the same time? Sounds like an electrical gremlin corroded sensor plug when you swapped it maybe some corrosion was left behind ? How did the plug on the harness look?
Are you the original owner ? Is it a saltwater boat ?
Nope it is your jet pump as discussed the holes on the left side where the square part with the hoses coming out is where the water to the engine comes from. I think you have sensor and electrical issues . Yamaha had a bad reputation in the past for bad heat sensors not so much recently. people would add resistors to the sensor pickup connection to fool the computer into thinking the sensor was still attached. Once you have issues with those it's never going to stop without fixing it.
I have no idea, I really didn’t touch anything on that engine, I’ll look closer when I get home, im99% sure all I touched was the thermoswitch and swapped it . But I swapped it back, so now it’s the original one and throttle still locked and check engine is still on .. doesn’t make sensehmm did you leave something inside the engine compartment that is locking up the throttle or is there something locking the reverse bucket just guessing
Where’s that located I don’t see it on parts breakdownMost likely the stuck throttle is something that is in the way of the reverse bucket.
