Want To Buy Engine replacement in 2015 fz-s
Jeff_FZS
Good day, i currently have a 2016 Yamaha fz-s I need a new engine for. Current engine was flooded and I had to remove. I wanted to see if any knows where I can purchase another engine, any year that will fit. Considering going with naturally aspirated. Any suggestion as to we’re I can inquire? Greatly appreciated.
Marvin willis
Morehead city nc
Did it lock up? I see sunken jet skis. And motorcycles and four wheelers all the time. Normally easily fixable.
I’ve got a complete engine, winterized but plug and play ready for sale for $5k. Came out of a 2010 242ls and has 506 hours on it, 0 on a new timing chain, oil and filter. I took video of it powering up and idling before I pulled the engine a few months ago. buyer must pick up in NCal, 94505. I will help load it. Also comes with “an out of sight warranty” that is once its leaves my sight the warranty expires.
Good day, i currently have a 2015 Yamaha fz-s I need a new engine for. Current engine was flooded and I had to remove. I wanted to see if any knows where I can purchase another engine, any year that will fit. Considering going with naturally aspirated. Any suggestion as to we’re I can inquire? Greatly appreciated.
I forgot to mention I will throw in the ecm at no added cost. I assume you would need it if your are converting from supercharged to NA.
Jeff_FZS
Hello, thank you for the reply, I made a mistake and my ski is 2016, from what I’ve read here in the forum the 2015 motor came with a chain issue which was fixed for my model year. I don’t mind going N/A if the engine is more reliable. Would have to look into the motor you have. How much are you asking for it?
Jeff_FZS
Just saw this, I live in nj, will look into the motor and shipping costs.
Jeff_FZS
Yes it did lock up, and started to rust, i pulled the engine out and have the hull ready for a replacement
$5k for everything originally attached to the motor including but not limited to the oil cooler, starter, coils, fuel rail, injectors, intake and exhaust manifolds.
around 2015/2016 Yamaha upgraded the engines with thicker timing chains. Most of the failures I read about were from the 2015 model years but one of my engines (had a timing chain break at 506 hours). As a result I had the timing chain in the other engine, the one I’m selling, replaced by a PWC shop with a new one, new but not upgraded, the new chain has less than 5 minutes on it. Yamaha sells an upgrade kit for around $2,500 parts only. Full disclosure, the oil cooler was replaced under warranty in 2013 (the 2010s, including mine, sometimes had leaky oil coolers), no problems with the new one.
let me know if you are interested not sure how shipping works but was told I had to build a crate around it. I’m not prepared to do that which is why a prefer pickup. There are several members here who haul goods for a living or as a side job maybe they will chime in. I’m hoping it would be as easy as piggy backing on another load from CA and i that would need to be done is get the engine and the dolly it’s strapped to up the loading ramp.
easyliving609
I'm in NJ. Have couple 1.8s currently if your still looking.
I’m in the west coast and will sell my engine for $3,500 cash . Buyer must pick up the engine in CA.
