Engine won’t turn over
Erodvrx
Chaparral
VRX
Hello I have a two twin 255 Rotax engine and I went to the boat ramp and both engines wouldn’t turn over. I started to hit the dead man switch and they both fired up. But after about a month of it sitting the lcd panel turns on but both engines won’t turn over . The battery are both good . I also checked the dead man switch and it was fine.
Dean P
Saint Petersburg, FL. 33702
Chaparral
VRX
waternutt
Panama City, FL
Chaparral
VR
I had the same issue a couple months back. I don't have an exact answer, but I did pull/inspect most of the fuses/relays and all battery cables, etc. Everything checked out fine. After that, the engines fired up and I have not had any starting issues since. 🤔
Erodvrx
Chaparral
VRX
Hello guys I had two bad relays . One on the port side and one on the star board side. Thanks Dean P
jerrytn7
SeaDoo
Speedster
im having an issue with a motor not starting,its a 97 seadoo speedster with twin rotax 177's and one turns over and starts but one I pi-ut a starter and starter solenoid on ,new battery but come to find out the driveshaft coming in from the jets isn't turning on just that one motor,tried to turn it by hand and it wont budge but the other motor turns freely.any ideas on what it is
