Face palm dealer 10hr service
Badger309
:banghead:And this is why you learn to do things yourself.
Literally just left the dealership. Picking up stuff to do the 10hr service this weekend.
Asked the guy at the counter for the yamalube marine grease for the bearing housing for the 10hr service.
He proceeds to tell me all that all you do for the 10hr is change the oil. So I argue a bit. He tells me that he has been a tech there for 8 years and they have never been required to grease anything on the 10hr all they do is change the oil.
Then hands me a squeeze tube of marine grease. I tell him I need a tube for a grease gun because its a zerk fitting and he argued again that there is no zerk fitting for service. I show him the service manual for the 10hr and he tells me that they have never done any of that and its not required.
HangOutdoors
Royal Oak, MI
My dealer and another one in the area dont grease at the 10hr. Either. Publications from yamaha indicate no grease and some say grease. I did not grease at 10 hr.
Badger309
Service manual literally says to grease and how much to grease.
HangOutdoors
Royal Oak, MI
Your call, as i said some do and some dont. You need to do what you feel is best.
Dixie Highway
Daphne, AL
If you decide to grease (I did) at the 10 hr, make very sure you do not go beyond the recommended amount. Many stories on this forum of too much grease blowing out the seal and creating a leak.
mwalker4
Delaware County, Ohio
In both the 2019 SX190 Owner's/Operators Manual and the Service Manual (Intermediate Housing: Lubricate: 100 hours or 12 months). It is not indicated for the 10 hour service in the table. Now I did throw some in because I used my 10 hour (14 hour) as my yearly the last year.
Badger309
Ya done some reading. There are so many different opinions on it. Ill throw a little bit in there and call it good
Dixie Highway
Daphne, AL
I measured how much my grease gun pushed out per pump, and subtracted a tiny bit (5%) for error and called that good. Now at the annual service I do like 2 pumps per bearing and call it a day.
EricE
Pennellville, NY
Just went through the manual for our 2020 212s.
The 10 hour service does not have anything about the intermediate housing. Only at 100 hours , and/or 12 months. I found it interesting that the dealer we purchased it from said not to bother with the 10 hour oil change, and wait till 20. The've been selling Yamaha for forever and are highly rated so I don't doubt they know what they are talking about.
Probably do the oil change at 10 hours myself, but it would probably be fine either way.
Still debating on whether to do anything about greasing the bearing housing or not... Used to do it in our jetski every year...
CORRECTION: It wasn't listed in the maintenance section, but in the "Care" section..
33 -35 cc after 10 hours or 1 month.
Guess I will do it...
Badger309
So for an update yamaha actually made it convenient to grease on the 2020. Ran a grease line with zerc mounted at the top of the engine.
Canuckjetboater
SX195
@Badger309 .....thank God for your boat that you know the proper procedures. Have heard the same comment a number of times. YES you do grease at 10 hours. This has NOTHING to do with the bearing but lubricates the seals in the bearing gear case. which prevents costly water intrusion. Some techs say don't bother with the oil filter at the 10 hour. What twang doesn't change the oil filter with the oil? This was discussed earlier today on another post. It is scary how many technicians are clueless regarding maintenance. I 100% believe it is up to me to prepare for any service. I have for 30 years presented a checklist to whatever dealership I had purchased from that the technician must check-off EVERY item then sign the bottom of the page. I observe all service. I also tip the tech at the end and no one has ever complained about that LOL. Every dealership I have bought a boat from knows I observe while the service is being done. My purchase, my boat, my $$$ for service - my rules. Got a call from a dealer the other day regarding a Mercury Axius ($20,000.00 guidance system) asking me a technical calibration question. GEEZ I now longer have cruisers with Axius GPS guidance! :) Know your boat and insist it be treated properly - educate if necessary.
