Evil Sports
- 91 North/75 South
- SS
So it not an issue to run without the ribbon ?
@Rod5 where is the rubber piece around the metal ribbon? if it is still in the intake, TAKE IT OUT!Ribbon and Air box boot removed. Note the inside diameter of boot is less than the volume of ribbon.
Good catch. @Rod5 please check and remove if still there, save it with the ribbon.@Rod5 where is the rubber piece around the metal ribbon? if it is still in the intake, TAKE IT OUT!
If you are chasing performance "ribbon delete" is the #1 modification for Yamaha 1.8l engines. When done right it has never been shown to cause any adverse effects in these engines. The ECU automatically adjusts to increased air flow, it is free power and better fuel economy.So it not an issue to run without the ribbon ?
Here is the part number jetboatpilot sent me. I ordered them along with the Seadek kit in the group buy a few weeks ago.View attachment 46892 The Riva rings today reuse the rubber spacer to keep the rings in place same as the ribbon.
i removed mine from 190 and also my 240. absolutely no issue and easy free gains.
While it is required, i do not feel the need for it. 0.000001% chance of burning down the boat...
I run 51 mph consistently.
Yeah yeah yeah. But the rings look good! LOL.i just find that the RIVA ring is totally unnecessary... each cylinder will draw in necessary air as the pistons & valves move.
Thank you - great refresher on this topic!View attachment 46892 The Riva rings today reuse the rubber spacer to keep the rings in place same as the ribbon.
Thanks.... its a 14 Suzuki DRZ400sm but after the first 100 miles decided it needed more power so i went big bore cylinder, race cams, and mechanical flat slide carb. Went from 30hp stock to 51 hp now.
Nice! I thought it looked like the DRZ. I had the FZ1 once too (my second most favorite bike ever) a few bikes back before I switched to the KTM's. Had the SMC 640, then the 990 Super Duke before I got the 1290 Duke last year. I thought about the Duc Hyper, but decided to stick with the KTM.Thanks.... its a 14 Suzuki DRZ400sm but after the first 100 miles decided it needed more power so i went big bore cylinder, race cams, and mechanical flat slide carb. Went from 30hp stock to 51 hp now.
I was spoiled when i lived up north had 24 7 access to a performance bike shop with a dyno so my bikes have been tuned to be optimal with what i put in it.
My FZ1 is tuned and modded as well
Want to get a Ducati Hypermotard some day. And the new FZ10. And the new FJ1300..... man so many toys so little space and money.lol
Sorry for the sidetrack....
Too funny! I was allowed to get a new bike but -- with a sidecar. So, I got a custom Ural Retro (M72 replica) which turned out to be a hoot. Incidentally, those are also pretty hard to handle and dangerous to ride actually, but wife thinks it is safer BECAUSE it has a sidecar... Go figure.
Unfortunately this is the only bike my family would sign off on for me after 2 in a previous life.
That's hilarious!!! What an awesome interjection there Evil Sports... LMAO!!!
