2016 AR240 performance mods
sac36555
Hey guys- I’m buying a 2016 AR240 with 50hrs on it. I want more low/mid end power for wakesurfing and we sometimes use our boat in high elevation (5000-6000ft). I don’t care if I gain any top end speed.
I’m definitely buying the Riva for a ribbon delete and Riva performance air filter/engine breather kit. I was on the fence about some of the other mods like the Solas Impeller, Riva Waterbox, Riva high flow exhaust, and the MapTunerX ecu reflash.
does anyone on here have all the mods done? Is it worth it? What mods were worth the money?
You are going to definitely need a different set of impellers. They make ones for your exact situation
Anyone else?
There really isn't much you can do to help give you more power, this has been talked thoroughly and not much can be done.
Lucky13 cones, seal the pumps will help
You’re at 100hp/liter from the factory so they aren’t exactly weak or detuned motors.
That would equate to the average V8 truck having 500-600 hp without a supercharger.
