FSH 210 Sport
- Tranquility Base
- FSH Sport
I don't know how accurate this online calculator is:
At 6200' it has a loss of 46.5 HP. That is almost a 25% decrease in power as mentioned above which I would guess gives you a top speed of around 40 - 41 or so. Impeller may help a little but my guess is you'd have to throw a tune and maybe a higher compression impeller in the supercharger to get back to 49 or 50.
I have used the Wallace racing calculator as well it is a good tool. However that too uses just the standard 3% per 1000’ of elevation gain 46.5hp/250hp=15%. The Wallace racing calculator assumes standard atmospheric conditions.
If you were to put in the density altitude at 6200’ on a 90* day, in stead of just ASL altitude of 6200’ the density altitude then is 10,800’ that comes out to a loss of 81hp/250=32.4% loss of hp.
The problem with increasing super charger speeds is that if you were to go to a lower elevation there would be excessive boost pressure which leads to a whole plethora of tuning and other issues that would have to be dealt with. Aka a PITA.
