bigwaves
I like it. Good job ??. There’s plenty of room on that pontoon for a second and third fire pit.
I was thinking the swim platform.I might do the same mod to my Yamaha.
I can just cut a hole in this hatch and Gud-2-Go !?
I saw this on my thread and was half hoping you'd start a thread so i could see the build process LOL! that is such a cool idea! Of course its dangerous, its a fire! its dangerous in the same way its dangerous to carry a loaded handgun in the glove compartment of your car. Can accidents happen? of course they can! will being responsible mitigate the risk of people getting injured? of course.
Definitely not something i would do, only because i dont have balls big enough to cut that much out of my boatThat would definitely extend the boating season here in Southern Canada that's for sure!
I was thinking more about it getting hot under foot from the sun in the middle of the day, hadn't even considered after use.
Either way it's a cool (hot?) mod!
The tinkerer in me thinks this is awesome (not something I'd do perhaps, but still cool). The Floridian in me thinks additional heat on my boat would be miserable lol.
I stay sober, lol, sometimes my guests do not, if that's the case, I don't run this thing. Keep in mind, we do get cold in the winter months, so this novelty has a limited window of use. The propane tank is located in the center stern/transom area, there are two vented compartments, port, and stern. All 3 areas are covered by the sun deck. The fuel tank, which I find more volitile than the propane cylinder, is in the starboard area. It's covered by aluminum sheet metal, and storage is avail on top of that sheet. Both shut off's are always utilized when the fire-pit is not in use. Tank, and appliance valve.Interesting mod for sure! I get why the naysayers are saying what they are saying....I might add a fume detector on the deck or near the gas tank since they aren't expensive. My primary concerns would be fume ignition, and then burns from the heated element (or lid).....but since @ChrisM says he's only boating with sober adults - should be ok....
Thanks for sharing!
I''m not thinking there would be much difference in the type/source of fire/flames when comparing to a marine barbecue grill.Only because the people who write the regs never imagined someone putting a fire pit on a boat.
Awful lot of histrionics about this, but this is quite a bit less risky than a grill that has a significant grease flare up. Heck, one time I was about to toss my magma into the water because I was starting to get concerned. Biggest risk here is a burnt foot, these little firepits don't throw off that much flame, and with the valve at an easy reach, would be easily contained. It's sufficiently distanced from the seats and surrounding carpet, too.
I love the idea, but I'd rather have it at pedestal height. I recently bought a little tabletop pit for my porch that runs off the 1lb bottles, and the thought crossed my mind to insert it into the boat table (with it over the water) - but they just take way too long to cool off for it to be practical to use and store.
This is the thing I saw on that "rebuild it" Youtube video.Have @HailMary make you a custom stanchion to fit our side tables mounts and you are good to go in the cockpit or on the swimdeck. Just sayin....
