Smiley
- Roswell, Georgia
- 195S
Working on installing my new tower speakers and noticed the flush mount option. Not sure if it will work but wanted to reach out and see if anyone else had tried it. The clamps on the swivel mounts are fine, but a little large.
![10337ECB-750C-4D79-8B40-58E9CD5EF4E0.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/172/172703-711823c4673a759bcffd93e2f8802a25.jpg)
While I was playing around with locations, I thought it might be a clean look to install the flush mount option on the crossbars instead.
![E5446655-618D-4C77-A974-4EF38B0A0F58.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/172/172704-dda675fe182c87d32cc1f964ac6da846.jpg)
Does anyone know if there is a hole between the front bar and the cavity in the cross bar like in the center one? I can see through the center factory hole that the wires for the light run through the front tube and then down the center crossmember.![0E3B43A2-4599-401F-A30A-F3718B64B07A.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/172/172705-02e8bfe5f56cf827125a8abb3f35dd6b.jpg)
Going to grab a boroscope tomorrow and check up inside the tube if I can get it in there. But, if anyone knows, it would save the hassle.
