Forward sweeping tower owners please check your lock bolts
robert843
Myrtle Beach, SC
As some of you may have seen during this years Bimini Fling several 15+ AR owners had issues with their tower bolts backing out and or striping. When I put my boat In dry stack back in May I securely tightened mine but this issue made me think to check them today and glad I did. Just from regular use they had backed out almost a full 1 and 1/2 turn during this time. This will now be on my pre departure check list every time to put my hand on the bolts and tighten them if necessary as last thing I want is them to back out and the tower to fall.
I wonder if you could use blue Loctite to prevent that from happening. That would give you a greater level of security while still allowing relatively easy removal.
That would likely work but may not be ideal for someone who had to raise or lower the tower consistently. Not sure it would stop one from stripping out but I don't think just tightend ing them will either.
This is clearly a poor design that could put someone in the hospital or worse. Yamaha does not make those towers so I would be in contact with the manufacturer of the tower to inform them of the design flaw and see what they will do about it.
Edit- My guess is that @swatski is already headed down this path and finding a way to improve the design himself.
I would imagine he is as well. Only thing I can think of at this time is to drill on each side and add a secondary bolt as a safety precaution
XTP is the manufacturer of the towers. They make towers for the OEMs while their sister company Monster makes universal/aftermarket towers.
I wish the AR style towers had locking pins as opposed to threaded bolts. I may just drill mine and use high quality locking pins because it's obvious mine is never going to be replaced with my November 2016 warranty claim of the paint chipping on the base (because the tower moves when you hit big waves causing the damage). Another option would be to safety wire them.
Mine have also loosened. I am working on an idea to use a pin to secure the tower. We use pins on landing gear for aircraft, so I am positive that it will hold the tower.
Possibly a clevis pin?
@1948Isaac, how has your tower performed? I would expect that you've given it a good workout with all of your saltwater trips. Do you have any thoughts on this?
Thanks
ya'll should bombard Yamaha with the issue and severity of the liability if one falls on someone...
Yamaha would need to get XTP to redesign the locking for the AR tower. Can someone with a newer 242X or Limited post closeup pics of their locking pin and handle?
I spoke with Wedowee Marine this morning about my other related tower issues for warranty and will be taking my boat in at the end of summer. At this point they said they will just powder coat my tower base again. Issue I have with that is that it doesn't address the issue that is CAUSING it to chip (tower moving with impact).
I am going to look at my tower good to see what can be done. But before anyone does anything they should contact yamaha first about the issue and what can be done
Yup that's pretty much what I'm wanting or wishing we had. Is that how the newer Limited and X model towers are or do they use a compression lever? Hard to tell from the Yamaha pics.
Not sure, @Julian how is your tower secured?
LS/X 2015+ towers already have a perpendicular pin and a more massive base.
I have thought about this, IMO, there is not enough material in the sheath metal sides that go over the solid aluminum base in Ar240.
I always verify the knobs are "securely" tightened before every take off...
@ThatJeepGuy @Majorsmackdown
Beware it can happen fast without warning, not necessarily a slow unwinding/unscrewing process. I found out the hard way.
Also my cabin upholstery in the aft and swim deck were littered with aluminum thread shavings after my tower collapsed unexpectedly indicating a violently stripped thread, not a wiggled out knob screw. IDK.
Oh, and the other security feature - the cable stops - make an interesting sound when they snap (and lend in under seat storage).
Have you been in touch or heard a reply from Yamaha on this yet?
If not yet please keep us informed on any news
The fact they stripped out is what really worries me! @swatski
I just went out and took some pics of my tower. My female base threads are not the prettiest but the tower bolt threads look good. It would be interesting to know the minor and major pitch diameter of the two threads. Personally I think there is some slop in tolerances there. You can see the rough metal surface around the tower base thread indicating the tower is banging against the base so there must be some movement happening there. Also note the damaged/chipped power coat on the top edge of the base. This I feel is from the little flat section inside the tube that makes content to the base when the tower moves from hitting waves hard or head on.
I have a big problem with a stainless steel bolt into aluminum threads.
Dissimilar metals like these in a marine environment dont mix well.
They should have had a stainless nut in the housing
