swatski
- North Caldwell, NJ
Sorry guys, I am still catching up - just got back.As some of you may have seen during this years Bimini Fling several 15+ AR owners had issues with their tower bolts backing out and or striping. When I put my boat In dry stack back in May I securely tightened mine but this issue made me think to check them today and glad I did. Just from regular use they had backed out almost a full 1 and 1/2 turn during this time. This will now be on my pre departure check list every time to put my hand on the bolts and tighten them if necessary as last thing I want is them to back out and the tower to fall.
Here are my quick thoughts:
Yamaha should be filing the CG4917 forms, promptly.
My guess is they (or XTP) tested those towers for dynamic loads for towing (behind the boat) and static loads hanging off of a tower. I feel those towers are adequate (robust) for towing and wakesports. And I'm sure you can have two 300lbs guys doing pull-ups off of those all day long. But that is not the issue (those towers seem more than adequate for towing but not for safely passing in rough water).
The issue is harmonic resonance and hull flex when pounding waves.
A pin installed across (or perpendicular to) a base would be one solution, as it is done in LS/X models.
In this context, the sheeting material used on the sides of the AR tower leg base (encompassing/sliding over the solid aluminum base - bolted to the hull cap) is way too thin (IMO) to support the structure with a pin-through. Would need to be redesigned or modified with weld-on plates etc.
