Augieol65
- Downers Grove
- Limited S
Hey boss @bigblank69 I got another question. I bought that Polk amp you recommended and plan on doing the set up you suggested. If I wanted to add one of those wet sounds sound bars and went with the surge 10 which is the one that has an amp in it but no blue tooth. Would I be able to wire that to control that volume independently of the rest of the system? Can I wire like an in-line volume control running to that bar or is there a better way? Might need your expertise come spring what’s your beer per hr rate?
