orexismd
- New Orleans, LA
- FSH Sport
It’s been a past year of Firsts since bringing home my first boat! Thank you for the numerous contributions this group has shared that have allowed for countless hours spent learning and absorbing information and being asked by my wife, “What do you keep looking at? You’re obsessed!”
Let me preface by disclosing I have no formal mechanical or electrical training but am an avid DIYer and dismantled the engine of my 1986 Camaro at the age of 16 and was unable to put it back together. So now onto starting my first audio install/upgrade. This was preceded by installing Lowrance HDS 9, NMEA network, VHF, MOB+ system, Ttop courtesy LEDs, Ridesteady and soon - TV wake fins. I feel this will be the most complicated and potential for error so putting it out there for critique.
Audio: 4 x JL MX650s, 1x MX10IB3 subwoofer, 1 x JL M700/5 amp
Batteries: stock starter battery (on solar charger), 2 x Duracell group 31 AGMs in parallel (on a Prosport 12 two bank charger)
Cables:
Power to Distributor - KnuKonceptz Kolossus Fleks Kable 1/0 Guage Power Wire Tinned Pure Oxygen Free Copper. Chose this gauge to avoid voltage drop off as part is being run through the hot engine compartment and I like to overdo things. Positive end connected to house battery switch, neg connected to house battery terminal.
Distributor: Audiopipe Pdcp1414 Power Distribution Agu Fuse Block
Distributor to Amp and Fuse Block: KnuKonceptz Kolossus Fleks Kable 4 Gauge Power Wire Tinned Strands of Pure Oxygen Free Copper
Fuse Block: Blue Sea Systems ST Blade ATO/ATC Fuse Blocks
Speaker Wire for coaxials and sub: KnuKonceptz Karma 12 Gauge Speaker Cable Tinned Oxygen Free Copper speaker cables - they were out of stock with 14 GA so went with 12 GA.
Fuses:
To be inserted on positive 1/0 power wire between distributor and house battery switch, approx 1 foot from switch in battery compartment- Bussmann CB185-150 150 Amp Type III Circuit Breaker
Amazon.com: Bussmann CB185-150 150 Amp Type III Circuit Breaker: Car Electronics
Using 150 Amp b/c plan on adding another amp to power future tower speakers (JL 7.7 or 8.8s - self xmas present.)
1 x 60 AMP Platinum AGU Glass Fuse for use in distributor block to Amp, undecided on distributor fuse to install going to the Blue Sea fuse block (will change depending on what I connect to it I guess)
Mounting amp and distributor to amp board inspired by @Mainah !
Power wire terminals secured by crimping 1/0 terminals with bench vice, hammering flathead screwdriver about ¼ depth for 2-3 indentions on the terminal, soldering with regular on acid paste flux and 60/40 rosin core solder and covering with adhesive heat shrink.
All wires will be protected with split flex tubing and secured ever 18” where applicable.
I think one of the largest dilemmas I am having currently comes in connecting the 12GA wire to the coaxial speakers. On the larger Positive speaker terminal I can use a ¼” female connector, but am unable to find a 12GA compatible connector for the smaller neg terminal. I’m planning on using the larger ¼” female connector with a combination of crimp/solder/ adhesive heat shrink. What do you think?
Cables:
Fuses:
