fishkiller7
- FSH Sport
Hey Last Summer hit 42 mph easily this year maxing out at 25 What? suggestions appreciated thanks
Did boat sit over winter? yes but added stabilizer with low amount under 15% fuel
Did you use/add any fuel supplement?
How much fuel have you used this summer so far? about 180 gallons
Not bad that you'll break something but definitely could be a performance issue,there is fishing line braid around impeller how bad is it to run it with it on there?
is that effecting the speed that much?
Look in the faq section on how to pull your pump,
Do both tachs bounce or just one?
How much do they bounce?
