Not trying to be difficult, but the Mr Cool DYI series seems to come with a pre-charged lineset, here is their website. It is another option. although I would agree it doesn't seem to difficult to flare the lines and pull a vacuum with the othersFast forward to 12:44 of this video. See the open lines?
It does not say that anywhere on their website. To be sure, I scrolled the manuals of all their products. They are installed exactly as all mini splits are setup.Not trying to be difficult, but the Mr Cool DYI series seems to come with a pre-charged lineset, here is their website. It is another option. although I would agree it doesn't seem to difficult to flare the lines and pull a vacuum with the others
Jim
Fujitsu has a series that puts out 100% of rated heated output down to -5 or lower…much better then some others. I know Mitsubishi has similar models. And maybe others do as well. But many of the second tier imports like Mr Cool do not have anywhere near the same cold weather performance.1. The Heat Pumps not working under 32 degrees is an older rule of thumb. Current air sourced heat pumps will have a COP 2.2+ at 10 degrees and 1.6+ at 0 degrees. Meaning they give 1.6x more heat than resistive heating per energy consumed. Thus, they will work fine with the proper sizing. If I spent a lot of time in garage in winter, this is the route I would go.
2. My configuration in Central Ohio 1000 sq ft insulated attached garage: Electric resistive heaters on Freeze protect and sized to heat quickly for times I want to work in garage. Electric heaters for freeze protect rarely go on except for nights a couple of weeks in Jan and Feb. I don't spend much quality time in the garage in the winter, so the initially cheaper but less efficient resistive heating works for me.
3. I have thought about extending a vent from house to the space, but have decided against it due to building codes (fire and fumes). Still tempted as I have a geothermal heat pump for the house, but I can't get over the safety concerns.
I don’t know if they still sell them but they have or had some that came with a special line set. It was pre purged with a special valve on each end ... Connect the lines and open the valves. No gauges or pump needed.It does not say that anywhere on their website. To be sure, I scrolled the manuals of all their products. They are installed exactly as all mini splits are setup.
See the link below, an example from the website you posted. Pay attention particularly to pages 24-29
Thank you @the MfM , this is the Mc Cool DIY (not their Advantage) series that I note above an what I have been trying to explain to @Wake_Dude. In my post #22, in one scrolls down to the video (around the 2:00 mark, you can see the capped lines as the tech connects them to the heat pump. I would agree the coiled up lines look ugly and look like the installation is not finished.I don’t know if they still sell them but they have or had some that came with a special line set. It was pre purged with a special valve on each end ... Connect the lines and open the valves. No gauges or pump needed.
You couldnt cut it to length so people were leaving the excess coiled up. Which is ugly and probably not good long term.
Nope! Still incorrect.Thank you @the MfM , this is the Mc Cool DIY (not their Advantage) series that I note above an what I have been trying to explain to @Wake_Dude. In my post #22, in one scrolls down to the video (around the 2:00 mark, you can see the capped lines as the tech connects them to the heat pump. I would agree the coiled up lines look ugly and look like the installation is not finished.
@Wake_Dude, I do appreciate the comment, "Mini splits are sold with enough refrigerant up to a given lineset length. If the lineset you want to run is going to exceed the refrigerant capacity of what was filled in the outdoor unit (sold as), an HVAC tech, or yourself (easy to do), will need to add more refrigerant. All of the regrigerant is housed in the outdoor unit when it is shipped. There is nothing in the lines." This is super helpful to know! Do they usually spec out the line length in the install manuals?
Jim
Okay, lets try this one more time. When I said lines were "pre-charged" that obviously was an error. As @the MfM, notes, the lines on some units (like the Mr Cool DIY) are "pre-purged" so no vacuum needs to be drawn. I know that there is a difference between "pre-charged" and "pre-purged" and this appears to be the point you are trying to across. I get it, and I appreciate you effort to educate me and it has happened. Bottom line, is that no flaring or the lines and no pulling of a vacuum in the lines has to be done and this is the selling point of the Mr Cool (although one would end up with the ugly coil of excess lines.Nope! Still incorrect.
Which model of DIY are you referring to? Product manual Link? The link I posted is for a "DIY" series mini split. Look at page 28 of the manual link. You can clearly see the tech place a hex key in the valve to release the refrigerant stored in the outdoor unit.
@the MfM The capped lines are to keep moisture and contaminants out of them. Some have a tiny amount of nitrogen or other inert gas in them to sort of "purge" the lines before making connections. They don't have any refrigerant in them. If the lines were in fact pressurized, the second you released the caps to make connections, all the refrigerant would turn to a gaseous state and shoot out of the line (possibly causing injury) into the atmosphere. I imagine it's also highly illegal to sell/ship a pressurized line like that.
Some of the Mr. Cool have "Quick Connect" couplings vs. the standard Flare nut setup. Those types of lines would need to stay coiled unless you trust your soldering/splicing abilities.......
I agree. The term "pre-charged" that Mr. Cool uses is a misnomer sales marketing gimmick. Like you said, all it does is eliminate the purge step; which is nice, but it's not a big deal to do anyway. No actual R410A in those lines, although the way they advertise seems that way.Okay, lets try this one more time. When I said lines were "pre-charged" that obviously was an error. As @the MfM, notes, the lines on some units (like the Mr Cool DIY) are "pre-purged" so no vacuum needs to be drawn. I know that there is a difference between "pre-charged" and "pre-purged" and this appears to be the point you are trying to across. I get it, and I appreciate you effort to educate me and it has happened. Bottom line, is that no flaring or the lines and no pulling of a vacuum in the lines has to be done and this is the selling point of the Mr Cool (although one would end up with the ugly coil of excess lines.
I have learned that flaring of the lines and pulling a vacuum is pretty simple to do, and the DIY tools to do so are relatively inexpensive (about $200). For my room above the garage, I may purchase one of the 18,000 btu DuctlessAire mini-splits and do the entire install (including cutting/flaring the lines and pulling a vacuum from the lines).
Jim
No problem Jim. I say go for it! It's a fun project that's not too difficult, and as you discovered, the cost savings is significant. More money for boat goodies!@Wake_Dude, thanks for your posts to this thread. Initially, I thought the units needed a tech and has since concluded its a job that I can handle. Big savings on having the unit installed. The HVAC sub-contractor on our house build wanted $5400 for the mini-split and the install. I'm figuring that I can do it for about $1800 (including some more tools, man I love an excuse for more tools!), then I qualify for a $300 federal tax rebate as my house will be an existing home and no longer new construction!
