swatski
- North Caldwell, NJ
I wouldn't worry about it too too much. Once on the water you can recheck the levels and adjust if needed.I feel like I took out slightly less than 3 quarts on one of the engines and put in just a hair over 3 quarts. Not sure if I should suck some out and then warm them up and re check dipstick and repeat until engines are close to same on dipsticks. It’s definitely reading a hair over full mark on dipstick
Keep in mind two things we have learned here. 1. If in doubt check the air filter for oil contamination, albeit the 1.8 are not as sensitive to overfill as MR-1s. 2. Whatever you do it is likely to be as good or better than your usual dealer performed oil change...
