gmtech16450yz
 - SF Bay Area
 - Limited S
Ok I have more good info for you guys that are seriously interested in knowing more about tuning and these SVHO engines in particular... (BTW, my "Like" rating to post count is one of the highest on this site. Thanks for the "Dislikes" you guys just gave me, it will help balance things out a little better. lol.)
I ran the GP yesterday after doing 3 more "mods". HUGE increase in low end and midrange pull and a solid 81 mph on the stock prop still!!! The limiting factor on top speed now is obviously the prop, I was slamming into the rev limit I set at 8500 on initial take off and on the top end. Raising the limiter would have easily gained more speed, I just didn't feel like it was necessary though, 8500 is as high as I want to run this stock engine. It definitely had the power to pull easily up to probably 9k, which would have been closer to 85 mph, but why?
So the latest mods were pump porting and sealing, a minor air filter change and more tuning work. On the pump, I did the usual tunnel clean up and sealing, but also opened up the 150mm section all the way up to the rest of the 160mm portions and removed about a pound of aluminum from the vane parts of the pump.
On the air filter, I had bought a Riva power filter in the first round of mods. I liked the filter and the flanges they use on the blower, but I didn't like the tubing. There's a really sharp bend right in front of the blower inlet which is never a good idea. So I ditched the entire tube and put the filter right on the blower inlet. I have absolutely no doubt it flows better since on intake tubing, less or none is always better than more.
The other part I worked on was I did more on the tune. At this point, I'm WAAAAYYYYY far away from stock and the "canned" tunes. There are points in the ignition timing table where I'm literally double what they did in the aftermarket tune. And big differences in fueling too. Like I've tried to say, these aftermarket tuners don't seem to understand anything but the WOT areas of tuning. There's huge portions of tables that are untouched from stock in their tunes, and it makes big differences in the way the engine performs in all the rest of the rpm and throttle ranges. There's more to engine management than WOT from 5k to redline, which is what anyone with a laptop can figure out in a couple minutes.
One of the side effects of proper engine tuning? Exhaust sound. When I first started riding this GP, I noticed it had a ton of resonance (most people mistakenly call it "drone") right around 4k rpm. When I put on the through-hull exhaust, it made it even worse. It was almost unbearable to run at that rpm, which happened to be right around where you'd cruise between no wake mode and up on plane. The exhaust noise was literally one of the biggest reasons I decided to tune this GP. Just as I thought, it was the tuning that was responsible for 50% of the exhaust resonance. Even with the through-hull exhaust, the resonance around 4k rpm is far less than it was with the bone stock exhaust and tune.
Long story short, (haha) there is a TON of potential in the SVHO engines. Just in tuning, far better power and response from IDLE to redline and ALL throttle openings is easily gained. There are also significant gains to be made over both the stock tune and the aftermarket tunes as far as fuel mileage goes too. There are parts of both the stock and aftermarket tunes where you might as well be pouring gas directly into the water. lol. I know some of you guys read some of what I say and think I'm nuts, but if you could see how different proper tuning looks like compared to an aftermarket canned tune, you'd be shocked.
Hopefully you guys with SVHO ski's will benefit from some of this info.
