Today I finished my KeelShield reinstall.  I am very happy, and also pretty tired.
Let's just say, these things really are not designed to come off.  Easily.  I mean, at all.
I knew it was going to be brutal, and I dragged my feet, I read and reread the removal instructions (uploaded below), they do not tell you it is going to be easy.  But, finally went to work on it this weekend, I had perfect weather - warm and dry.
First step, removing the damaged KeelShield was the easiest, actually.  It takes two people and a heat gun, but it does eventually come off, and in my case - in one piece.   You can see the rip in the middle of it, it got bigger as we were tagging and pulling on it, and you could tell the urethane material was fatigued from the impact.  I sure am very glad I had it in place.
The rest of it was just brutal cleanup.  And I mean - ten times worse than removing hydroturf.  The urethane strip/belt comes off, but the 3M compound/adhesive does not...  I initially tired just about every solvent including goof off, pure acetone, brake fluid, you name it - nothing touches it.  Nothing.
So, the only thing I was left with was just a slow scrape of small sections after good warm up with the heat gun.  Here you can see - the majority of the material is removed on the starboard side of the keel, and I'm working my way down on the port side.  That took most of the time, spread over two days.  Once that thick stuff comes off, the rest of the glue is semi-amenable to brake fluid, and more slow scrape.
Did I mention slow scrape?
My best friend:
After the clean up, I used the activating fluid/sheets and reinstalled the new KeelShield with no major issues.  At 9ft, it was a handful, but I had it warmed up nicely laying in the driveway in the sun, and it went on strait with no issues.  I used a roller, and then more roller in sections warmed up gently with the heat gun.
As per Gator-Guards recommendations, I finished it off by running a bead of 100% silicone along all the edges.
Done.
I sure hope will never have to do it again!
