mrcleanr6
- new jersey
- 275SD
The etching of the gelcoat is no big deal. You just loosly tape the keelgurd to the bottom of the bot with some masking tape then take the same masking tape and mask the border where its going to make contact when its installed. Pull the keelguard off then just sand the gel real good with some 220-180 grit sandpaper. Wipe it all clean with acetone, apply their primer then peel and stick a little at a time working your way from one end to the other.
