Help me decide: Scarab or Yamaha 195
H20Thrust
Bayliner
Dear Torn,
Big decision on buying a boat. away from Rotax superchargers, Rotax engines with out the superchargers are good reliable engines. I believe the Scarab your looking at has no S.C. ?? If it does have a S.C. stay away.
It’s a 250 HP 195, so that means it’s supercharged right? Why do you say stay away?
Farny
Spring TX
Centurion
Thank you! Lots of good info here.
I went and looked at the 2017 Scarab today. It was listed as “meticulously kept” but after driving 8 hours round trip, it looked like it had been dragged against a brick wall for all 6 years of its existence. So much dock rash. Engine hours are very low for this year, but it’s still concerning, the cosmetic damage.
For the same price, I can get a nearly pristine Yamaha. Such a tough decision.
I really like the Scarab, especially with the added Wake package because it allows me to do something the Yamahas can’t, at least not stock. But is that worth a boat that’s been neglected cosmetically?
Guess I need to keep shopping. Or just buy a clean Yamaha and make it what I want.
To be straight up, never owned or been on a scarab. I own a 195s and love it. The single engine Yamaha can actually be very surf able. Never will be a dedicated surf boat, and takes some bag filling etc. but I’m 180-200 and have no problem going ropeless. I really don’t think you will be disappointed with a newer Yamaha.
RodSibley
I have owned 3 separate craft with Rotax Supercharged engines; All 3 superchargers failed, causing severe damage, all 3 did not have high hours, Rotax SuperChargers give you a lot of HorsePower and Top speed, They will fail and cause damage. The average boat owner is looking for a reliable dependable low maintenance boat for the family, Rotax superchargers are not for them
jdkaeser
Cincinnati, OH
195S
@jdkaeser Just to make sure, you're aware your boat CAN take lower octane right? Having the higher octane helps with performance but your engine can take as low as 87 octane in North America. It will work just fine, just won't necessarily give you full performance.
@Michal Yes, older models need a rebuild of the supercharger. Switchover happened around that time. I think it was 2018... so 2017 and previous would need them. There's a way to tell based on a specific nut on the supercharger.
While the Rotax in Scarab might be tuned to be able to take lower octane fuel, the Yamaha SVHO definitely is not. You will get detonation and the knock sensors will tell the ECU to dump a bunch of fuel giving you terrible mileage and less performance. The purpose of the SVHO is performance, if you use the wrong fuel it kinda of defeats the purpose of having it. That was my purpose for stating that if you always trailer your boat, get the SVHO and hit a gas station on your way home. If it is going to live on a lift or in the water and 91 octane is never available, get the regular HO engine. Most of the docks I hit only have 89.
Jim_in_Delaware
Southeastern DE
Did the superchargers fail within the rebuild period? I would be curious to know the years of the engines that failed?
Thanks,
Jim
Winerocks
Bloomington, Indiana
Scarab
HO Impulse
I have a 2015 Scarab 215 with SC’s Rotax engines, and have had no issues…period. Well over 100 hours on each engine. Keep in mind a lot of Rotax SC issues are on jet skis, which tend to be driven differently (jumping waves/wakes, etc.. I’m sure I would be every bit as happy with a Yamaha, but have not regretted or questioned the Scarab for even one second. Yamaha boats seem very well built, and also seem quite reliable. My experience is the same with Scarab. Test drive both, make your pick and don’t look back.
Barry165G
Scarab
165 G
Imho, clean out ports are most important on a single engine jet boat. If you have twin engines at least you can get back to dock one one jet so not as important.
Can you explain a bit more why clean out port is more important In a single engine jetboat?
fireflymedic
Bonifay, Florida
On a single engine boat you are dead in the water if you can't clear the rope or other large item that may be blocking the jet. On a twin you can limp back to the landing on one engine.
I do admit small plant life debree may be freed with the reverse move as the shaft is supposed to be shielded on the scarebs but a rope is going to shut down any boat even a prop boat is in trouble with a rope.
Barry165G
Scarab
165 G
Thanks the info! now I have to be very careful.
