marcham
- Comox, BC
- AR195
Thanks for all the replies. A couple of you described exactly what I would want - push the throttles full forward, and the RS gives the desired acceleration, which can be adjusted to suit a given rider. However, @PeterB says it doesn't control acceleration, only max (i.e. set) speed. I agree that's also a good thing - I've also experienced accidentally letting the speed drift up while pulling a skier - but the biggest issue I and my family have is the "quick but smooth" acceleration with the rather non-smooth throttles. If I give too much throttle, I yank the rope out of their hands or pull them over; too little throttle and they fall before getting up.
So, I just spoke to Justin at RS, asking him if it would help me with smooth initial acceleration. In a word, he said "no." The RS system does essentially nothing until you're within one mph or so of your set speed (that's a direct quote, or as close as I can remember). He went into some technical details about why they did not take the approach that the Yamaha E-series did to achieve this benefit, which basically boiled down, like everything, to "pros and cons of each approach."
So, the RS system definitely has benefits, and jetboaters seem to love it, but it doesn't seem to have anything to do with initial acceleration. While disappointing, I still may go for it. And, sounds like I need more practice with the throttle levers.
Thanks again for the input.
Correct. If you are working with beginners, acceleration needs to be metered by the driver anyway. I would really only see and advantage for that feature for any experienced surfer to ride behind a boat with an inexperienced driver.
