- Royal, AR
- SX
The missing pins are for 12 volt charging and electric trailer brakes.Doesn't appear I can connect backwards
@Bruce I been looking online at 5 to 7 pin adapters and they all look like the one I have
I know I should have good wiring because my 33 ft travel trailer brakes work
You need make sure that you have 12 volt positive and negative going to the solenoid in the trailer tongue that disables the brakes when the truck is in reverse. Do you have a multimeter or test light that you can check with? You also can visually inspect the wires to see if anything is broken or disconnected.
