LS2000nKY
- LS
Ok, so yesterday I took the boat out and everything was running great then after about 30 minutes running around 30mph then the port engine suddenly stopped. It cranks over, but won't start. Fuses are good, cylinder compression for the three are around 115psi, I reversed ignition switches with no luck there, I took out and reversed the two throttle connectors, no luck there. I double checked the battery everything was snug. I decided to put about a tablespoon of fuel in each carb throat and it only cranked, not starting. My next guess is the starter solenoid, but if that were bad would the engine even crank over? I was also thinking maybe the spark plug wires are bad? Any advice is much appreciated.
