BrentP
- Navarre, FL
- Scarab
- HO Impulse
Last year (November-ish) I had a starting issue after the battery went dead. I finally found the relay switch information on this forum (thank you very much!!!) and bought some and now the boat starts perfectly. I put in both relays a couple of months ago (February-ish) and the boat started perfectly but it was only in the yard and I hadn't put it in the water yet. I went out of state for work and just got back and wanted to put the boat in the water. We went out this morning and when we put the boat in, it went into limp mode and popped several codes and overheated. Through some work on here and on the interwebs, we figured out that one of the relays might be in upside down (only one of them can go in upside down). I flipped the relay and sure enough the overheating and several codes went away but I am still getting the below codes. I have checked numerous sensors and all of the fuses and cannot find anything wrong. I have tried resetting the codes (couldn't get the mode + set to work) and have unplugged the battery for about twenty to thirty minutes. I just bought the boat last August with about 45 hours on it (older couple who bought it to use with their grandkids but didn't use it much and it was always kept in dry storage at a marina) and I have not had any problems with it other than the relay...until now. Does anyone have any ideas on where to start? I have the 2014 Scarab 195 HO Impulse with about 55 hours on it. I will keep looking on here and other locations but am getting frustrated. LOL. I am pretty sure it must be something electrical but I can't figure it out. Thanks in advance for any and all input!!!
P0300, misfire on random cylinders
P0301, misfire on cylinder 1
P0303, misfire on cylinder 3
P0523, oil pressure sensor fault
