4x15mph
- Downingtown, PA
Enjoy the boat. You sure did get this quickly along with getting it wet.
Congratulations on your new toy. Check out the tips and ideas section of this forum. There should be some prep charts that you could modify to help you out. As for the trim, as you get more use to it, you will be able to feel the proper adjustment as you boat. The proper trim, will get you, max speed, for the RPM you are traveling. You can hear it.Other things I learned today.. disconnect wiring before putting trailer in water.. haha.. trim up when towing, trim down when taking off and trim up for max speed.
Congrats on your purchase. As far as your skeg, this is what I did with mine on my Sea Ray. Its called a skeg Guard.
http://www.ebay.com/itm/Skeg-Guard-..._Accessories_Gear&hash=item4ad9dc8477&vxp=mtr
Its easy to do, and it holds up very well. Also get a stainless prop. I suppose you have an Alpha one drive on that Merc. I had a 21" Vengance prop on mine. Its a great all around prop. Also, looking at your pictures, you need to check your sacrificial anodes. You can replace them fairly cheap. Good luck!
