House items not powering on
Msurace
Limited
All house items, bilge, blower, radio, lights not working. The red light doesn’t illuminate on rocker switches. Batter is fine.
Seno
Lithia, Florida
Battery connections all tight? Have you checked fuses? Battery switch?
Scottintexas
Corinth, TX (DFW)
you should have a fuse mounted on the wall by the battery, it may be up higher and hard to see, it supplies the helm power,
Msurace
Limited
thank you for the suggestions. The battery terminals are tight. I even switched batteries and that didn't work. I checked fuses that are mounted on the back wall of the engine compartment. All good with an Ohm meter. I have to check the fuse by the batteries. I didn't know about that.
The power worked fine until i was having trouble with a DC inflatable pump. That wasn't working so i tried to clean the contacts and rotate it in the cigarette lighter. after that nothing worked. I took the dashboard apart to get to the cables and all are connected and tight. Grounds are also ok. if feels like a fuse to me and i didn't know about the one by the batteries. I will check that out this weekend. Thank you
