haknslash
- Lake Martin, AL
- Moomba
- Other
For new jet boat owners it seems retrieving or controlling the boat at slow speeds is the biggest issue, especially when around the dock or retrieving on the trailer. It was blowing a steady wind on Friday but I figured it was a good opportunity to show how I use both of these features to control my boat when I retrieve. Notice the wind was blowing pretty good and it takes pointing the bow into the wind to keep a straight heading since the wind was blowing across from the port side. If I didn't compensate for the wind then the boat would have certainly drifted off course. At the very last second I will turn the boat back towards the center of my truck so that it lands on the bunks straight. Normally I approach my trailer in No Wake Mode setting #1 (first tap) on a calm day but on that day it required setting #2. I keep the throttle in the first detent so that TDE is engaged and if I need to slow down for some reason there's no need to panic, just throw it in the first detent of reverse to keep both NWM and TDE engaged. Also note that my bimini was not deployed but if it were it would act like a small sail or chute so that would mean you would need to compensate even more to keep your heading.
Just wanted to show that even in windy conditions these boats can still be manuevered just fine even with the stock rudder on the newer boats. Some people may prefer to use the throttle(s) entirely with short bursts of thrust but I find using NWM and TDE allows me to concentrate on my heading and not worrying with the throttle aspect + steering while using momentum and thrust to my advantage.
