How to access hand rail hardware?
merlinjet
Laughlin, NV
Waxing the boat today I noticed the forward port side hand rail was loose. I need to get to the nuts that secure the rail but they seem to concealed somewhere behind the forward seat cushions. Anyone got any experience accessing the rail hardware? Thx
biffdotorg
Pelican Rapids, MN
Not as familiar with the 23' hull. But those of us that have done this removed a bow speaker.
A socket with knuckle and extension should get you in there. Long sleeves would protect you from some unfinished fiberglass in there. Good luck!
Babin Farms
Lower Alabama
Through the speaker hole for the front and try to get the rear from there or you can access the rear hardware from the helm compartment & head compartment.
props2you
Round Lake, IL.
@merlinjet HA...Funny you should ask! We were out a few weeks ago and noticed the same thing, the OCD in me absolutely could not let them just be loose! I ended up locating the hardware along the inside of the boat wall, but had to access it through the port/starboard seats/storage.
I ended up having to be upside down with my legs straight up in the air with a 3/8" wrench with extensions on a 13mm deep-well socket and a flashlight looking up towards the rail so I could see to get the socket on and tightened them up. Not terrible, but I'm also 6'2" 240lb so my wife was amused!
merlinjet
Laughlin, NV
Thx! I'll give that a try.
merlinjet
Laughlin, NV
Always more than one way to skin a cat. Not looking forward to this... This rail is more than just loose; I don't even think there is a nut on one side anymore.
whatever way you go make sure to put a gob of locktite on it so you won't be doing it again,
merlinjet
Laughlin, NV
you may also consider taking out the front wall in the closet, it's not that difficult, otherwise get an extra long extension for your socket
this thread will show you all the seat cover attachments,
Thx! I'm sitting in the boat right now looking at that very wall wondering how to get it out. This is just what I need. I tried the bow storage approach but that didn't go well.
the wall should come out with maybe 4 wood screws under those round plastic covers, I can't remember exactly at the moment but I think it slides out pretty easy,
merlinjet
Laughlin, NV
I'm in but no nuts or washers to be found. Do you know what size they are? 10m?
don't know, if you can get in the helm compartment you can reach the rear fitting of the starboard rail to get one of those off for the size,
