@dgfreeze would have to answer for sure since our boats are slightly different,How did you remove these cockpit side panels? View attachment 120790
Lol, make yourself skinny... you have to lay down IN the rear compartment, with your head toward the front, and legs and feet wherever they want to be, then reach up in and over a plywood divider, and undo one nut. Then, for the starboard side, I had to take the door off the helm compartment, to allow my chest to fit through, and scoot almost all the way in, being careful not to stress the steering system, as the steering cables are in the way, then reach rearward to access the three nuts holding the front triangular section in place. Once those four nuts (and washers) are off on each side, it’s just a matter of gently prying it off. Biggest hurdle is fitting into the compartments.
Thanks - I was afraid that was the case. I was also thinking I could take out the side well and reach up to get to it
I have a 2008 AR210 that I likely just need the couple back engine hatch cushions reupholstered - so I'm trying to match the white vinyl that's already on the boat -- do you know which color and brand of white was used on yours? Closest we've found so far is Morbern Newport Chalk. If you could tell me what color and where you found it I'd greatly appreciate it.More details later, just wanted to share a picture of today's install (except engine hatch, still working on new insulation)
View attachment 111789View attachment 111790
Thank you.
Picked up my cushions today, they look very good for what I've seen, they're shrink wrapped and i was surprised to see he found the hammer tone top fabric, it will probably be a few weeks before we install them
