anmut
- 212S
No software updates I'm afraid. It has been crazy with COVID this year just trying to keep enough inventory, so that's been the primary focus.
Do you find manually offsetting the jet thrust makes a big difference in the surfable wave?
It does, next summer I'm going to play with it more to find a good sweet spot. My issue is that I love that RS sync's the engines, which is awesome for everything but messing with the twin throttles and surfing. The menu option for that is deep and a PITA to switch on and off between surfing and cruising.
It would be cool if you had a "surf side: port/stbd/off" option on the main screen and a deeper "surf side reduction RPM" in a deeper screen. So you could set the reduction you wanted and then change your surf side on the fly and easily go back to sync'd motors after the session.
BTW, Ridesteady was THE BEST mod I did on my boat last year, hands down. Turns a decent water sports boat into an actual water sports boat. Also, since I like to surf and my wife has to drive, possibly saved our marriage.
