ridinpropless
- Canton, GA
- Limited
I think I did it! I believe I have officially quieted my Yamaha to the point where it is a very comfortable and pleasant ride, even at cruise speed. I read a ton on this and other forums to start the process, but added my own spin on it as well. I actually started by wrapping the entire engine compartment with this stuff I got for $50 from Home Depot: http://www.homedepot.com/p/4-ft-x-8-ft-Acoustical-Barrier-DB348X96BX/100663624 I liked it because I could wrap the entire engine compartment without any seams.
I stuck it to the side with this from Autozone: http://www.autozone.com/sealants-gl...aerosol-spray-super-trim-adhesive/708718_0_0/
Then I added this stuff on top of it: http://www.raamaudio.com/package-1-...s-ofensolite-iuo-peel-and-stick-41-625-sq-ft/
That gave me enough peel and stick panels to do the entire front and sides of the engine compartment (not the back), as well as the engine hatch and gas tank cover. I added the factory foam back on the engine hatch, just for good measure. That helped a ton.
Still wasn't satisfied, though. I bought another roll of the Home Depot stuff. I pulled the carpet from the inside walls of the rear storage compartments, laid it out on top of the rubber as a template and cut the rubber to match. Used the same 3M adhesive to glue the rubber to the carpet, and then back to the inside of the storage compartments. It made a HUGE difference! I thought it had, but wasn't sure. We went out with a buddy of ours in his 2013 242 and everyone in my family commented about how much louder his boat was than ours. For the price and couple hours of work, I would encourage everyone to do it.
Still looking for someone else with a non-modified 230/232 to meet up with to verify. Anyone?
