McMark
- Monongahela, PA
Where did you mount the second xducer?
Yes - per the Lowrance installation instructions. That allow it to get into non-cavitated water. I also found that as the easiest solution to mount my transducer horizontally with having to punch a bunch of extra holes into my boat. I only have a few penetrations that easily sealed up with 3M 4200 quick set sealant.
I haven't had any problems at all with it. That drain line is the white hose that goes in between your motors and is the passive drain for your deck in the boat. I cut a small hole in the line to get the wire through and then sealed it up with 3M 4200 and water proof tape. So far I haven't had a drop and we take her out about 3-5 per month for a few hours each time.@Bennie - I just got my boat and haven't noticed where the water line is, with running the wire through the drain line, does that exit above the water line when sitting in the water? That looks like a great solution for me, just wondering if water gets into the engine bay from there at all while sitting still in the water, like at a sandbar or something.
Here is mine a use a 7" galaxy tab 2 for gps. I use a suction cup ram mount to window. I have never taken it off and it has never come loose yet in very rough seas. Love it. Sorry it is a night shot all i had
New boater here so simple question...since i will already be using my iPhone for Apple Music and have it mounted on the dash, why not use a $10 app for chart plotting? I realize its not getting the transducer and fish finder, but its also a few hundred less. Just making sure i get how it all works.
I use ram mounts with the suction cup end. With Ram Mount holders made for the tablets. They make them for almost every tablet. I Stick it to the side window and the front window if running 2 tablets. I use a program called Navionics for android. It has great maps and with the sonar attachment has depth and fish finder also in app.
here's mine and it works great hereView attachment 28081
@Bennie My transducer cord needs a 1" hole for the connector. Is that the same size that yours was running through that opening?
