ross l
- Westfield, Indiana
- Limited S
I pulled a pump because impeller housing ringing. The ringing was getting severe. I think I will have to replace the housing because of the galvanic corrosion issue. It seems like the whole housing is getting smaller evenly rather than a few raised spots that I've seen on other posts. Anyone have a similar experience?
One of the bolts came out very hard and had buildup on the threads. I want to run a tap into that hole to clean the threads. I think they are 10mm X 1.25. Anyone know the thread size?
Thanks
Thanks
