- Royal, AR
- SX
This is my bearing change thread. It was an easy process. Getting the impellers off was the only hard part.
I was within 200 rpms difference at WOT, but that was mainly due to the L13 cones, and running 3 spacers on the port side, vs none on starboard. There was a pretty big difference before I installed the cones.How did the boat run before the current issue? Was your RPM at WOT similar on both sides with the OEM impellers?
If it was similar it may be similar to the new hulls where they stock both pumps with the same pitch impelelrs and the differences are very small, negligible for most people, and may not need/benefit from different pitch much.
You still haven’t pulled the impellers off, right?@buckbuck I have been reading about that. I've read every impeller thread on the forum in the last 23 hours I believe. Ha. I haven't decided on the gear oil yet. I do think it's a good idea, but I would want to tap the cone, and I'm not sure I want to do that with the L13s. I'll keep thinking on it. Had some good success this morning with impeller removal. Starboard side slid right out, nothing more than a pull. Port side (damaged bearing) needed a BFH, but it too came out without much fuss. I put a long impact rated extension through the intake grate and onto the impeller nut, couple a big boy whacks and she was out. So now to choose and order parts. I saw where @Bruce ordered a pump kit that had bearings and seals in it. Have those parts changed over the years? Should I order the kit or piece the parts together from the parts catalog?
This should be great!All parts have been ordered. Going with 6CW impellers and delrin wear rings. Impellers arrived today.
Wow. Can not wait for you to try those on!Here's a shot comparing the impellers. 6CW01 on the left and 6AP10 (stock 212x, at least for 2013) on the right.
