Jade63
- Kennewick WA
- Limited S
Totally agree. Unless you submit your own measurements, the existing template will be used to cut the SeaDek and if your seat is off by a little, you will definitely have an alignment problem. When I installed mine, I had to finagle a few areas for the best fit, but I understand that I did not have to go through the trouble of taking measurements and sending in a template of my own. I was fine with taking my time and figuring out the best fit and not paying for "custom" work.I get the complaints everyone has here about it. I hate to hear the bashing against the seller though, I assume you mean Will at Jetboat pilot. He is the greatest guy out there, supports us and stands behind his product like no other supplier. He cuts his product with a CNC machine, which means computer controlled and means they are cut exact. His templates are only as good as what WE have supplied to him. Now think about that, if these templates fit well on most boats and miss on a few, think about how these parts are installed at Yamaha. Now we are getting closer to the problem. I am not bashing on Yamaha either here but pointing out a reality of manufacturing. Locate in place in the field. Yes, it may be off a 1/4" and the result is what you are seeing here.
My opinion, yeah it could be done better and more consistently by Yamaha, but it is the realities of manufacturing.
Now to truly put myself in the same boat as all of you, this weekend I am installing my SeaDek. I am sure I will run into the same issues...Just trying to set the record straight that the problem is not our supplier. If there are concerns about the templates, you certainly have the opportunity to make your own template when you order too.
