Installing new Bow Roller and Shield while on the trailer?
ken4motion
Center Moriches, Long Island, NY 11934
252SE
Any ideas as to how I can get these parts installed while the boat is on the trailer? Any way to safely lift the boat a few inches so I can do the install? IMG_20140912_194456.jpg
I installed my roller while the boat was in the water.
But others have installed the roller with the boat on the trailer.
I believe that if you slack the winch and remove the factory roller you should have sufficient room to install the shield then install the new roller.
Andy S
Chapin, SC 29036
Cobalt
If your winch stand is bolt in place you can loosen it, slide it out of the way, do your work, and then slide it back in place.
jetboater4life
Rochester, MN 55901
After unclipping my winch strap from the bow eye, I was able to unbolt my roller and install the new one without issue. I did not need to move my winch.
beachbum
Niagara Falls, Ontario, Canada
My boat was on the trailer.... Was just enough space to swap it out
jdonalds
Redding, CA
This is exactly why I bolted the winch post instead of welding it.
GTBRMC
Waukesha, WI
I realize OP may not have had ability to drop his boat in the water, but the swap took me no more than 8-10 mins when I did it a few years back with the boat off.
We went to local lake. Dropped boat in water as usual. Moved boat to staging pier away from ramp. Parked truck & trailer. Swapped out the roller (had pre-staged proper tools in back of tow vehicle). Tossed the POS black OEM roller in trash can. Hopped in boat and had a typical family day at the lake. Easy.
Note: I have a 2008 trailer manufactured by MFI, so my bow roller yoke is a true 4" and did not require any adjustment.
ken4motion
252SE
OK, now that I have the old roller removed, how do I get the ULT-4 center section installed between those tabs? This is for a 190. How do I go about correctly bending those tabs to accommodate the width of the new roller? Also, is that center section supposed to roll or is it fixed?
Andy S
Chapin, SC 29036
Cobalt
1. Yes the center roller should roll.
2. Use some type of wrench to gain leverage to bend out the tabs enough for a fit, shouldn't have to move it much. You can use a large adjustable wrench, pipe wrench, vice grips, etc.
Zeus2013
Farmingdale, NY
So, the bunks will support the boat enough to not need the roller?
ken4motion
252SE
Ok, mission completion on the roller. First off, to get the bow off the roller I placed a wood board on a floor jack and raised the jack enough so the wood touched the front bottom of the hull. From there, I lowered the tongue just enough to have a workable space. I have to thank fellow member Leojay for that idea.
The bending of the mounting tabs was somewhat involved and it took me some trial and error to get it right. I used a vice grip and an open end wrench to get the right articulation of the tabs. On to the bow shield install!
ScarabMike
Green Cove Springs, FL
The bending of the mounting tabs was somewhat involved and it took me some trial and error to get it riView attachment 12203 View attachment 12204 View attachment 12205 ght. I used a vice grip and an open end wrench to get the right articulation of the tabs. On to the bow shield install!
Awesome idea!!!!
CFD3Captain
Coshocton, Ohio
Moomba
Wake
:) Nice work! You are not the only one installing the Stoltz on the 190 series. Put mine on my 192 yesterday. Not sure I bent the tabs enough (I was at the lake and didn't have my assortment of tools) but I bent enough I got the center roller on :) Night and day difference in feel between the two!!
Englewoodcowboy
Ceres, VA
I did mine by loosening the bow strap and hooking my UTV to the boat and pulled it back a few inches, but as the old saying goes, there are more ways than one to skin a cat and I also hear the Chinese say they are quite tasty...
Englewoodcowboy
Ceres, VA
The bunks carry the boat. The bow roller keeps the boat on the trailer when you have to jump on the brakes, it is a bow stop and that is all.
rkluck
Powder Springs, GA
Where did you get the shield from?
