- Corinth, TX (DFW)
My perfect pass has been acting up, I initially thought the battery issue was causing this but now wondering if the PP isn't the culprit,
still trying to make it work in my head how the port engine can fire and run, try to start the starboard and get nothing, immediately go back to port and now that doesn't run and won't until I disconnect the battery cables and then they both work ???
still wondering if there is a common connection somewhere behind the dash or since PP is linked to both engines if that's the problem,
anybody know what the circled item is, white box with orange top? my PP is wired into it ( I took power from the speedo gauge which was removed for PP install )
