Welcome to Jetboaters.net!
ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
Can you find a generic Catch Can at a cheaper price? Yes. Does it come with the proper hardware, detailed instructions, and available support needed to install it on a 1.8? No.
Everyone is different, and some prefer to spend a few extra dollars to have an easy install versus the headache of trying to make things work on the fly. Some may not even have the know-how to do so either. Food for thought.
Sure can. Catch Cans are quite big in the general automotive community and especially with those that build high-performance racing engines. All engines, regardless of being brand new or not, experience blow-by. Blow-by is known as the gasses that build up in the crankcase produced as a result of combustion. The amount of blow-by experienced varies between new and older engines as well as supercharged and naturally aspirated engines. This gas needs to be removed from the crankcase due to pressure build-up, so manufacturers add breathers to the crankcase to vent them out. Most of the time, and in the case of the Yamaha 1.8, the breather connects to a nipple on the air intake. So why is this a problem? Well, blow-by contains oil vapor that robs performance over time due to fuel degradation and coats your air intake duct/throttle body with oil residue. Our Catch Can Kit will "catch" this oil vapor and allow you to be able to empty it out rather than letting it get into your engine.
I was inspired to create a kit for our jet boats after 1. Cleaning my air intake duct/throttle body after 200 hours and witnessing how much oil residue was in it and 2. Learning that nobody else sells one specifically for our jet boats. I run this kit in my personal boat and have already caught a good bit of oil within 20 engine hours of installing it (see attached picture).
Thats what I was wondering. Commercial vehicles with air brakes have air dryers with the same type of stainless steel screen to extract oil and moisture from the system. Good info. So contrary to what one member quoted earlier, these do in fact fit the newer 1.8 engines.
Just ordered the flush valve, looks like a cool piece of equipment that you don’t have to be jumping off the boat all the time to turn off the water hose.
Jet Boat Supply are here in the central Florida area. Let’s help support our small businesses. Got my piece delivered to my door after ordering just this morning. Talk about customer service.
We offer two types of valves currently: tow valve to keep water from getting in the engine while towing and the flush valve to prevent you from having to get off your boat after starting it to turn your hose on when flushing
@jetboatsupply Got my order today and I like the trash bag hangers. I'm not sure if I'm going to use the tow valves. I was expecting the internal valve to be a metal ball valve, it's not. I can't take the chance that the internal plastic mechanism won't fail under pressure. I'm going to opt for some stainless steel ball valves. I'll use these in my flush lines instead. Also, you may want to include stainless steel clamps with the valves.
