IS ANYONE NOT HAVING WATER/LEAK ISSUES?
After 4 weeks at the dealer to figure out where water was leaking into my center console storage area, they finally delivered my boat back to me. Previously, I have sealed the anchor storage thru hull fitting, fish box drain and the 2 center storage floor drains. The dealer installed a float type bilge in the engine compartment ( in addition to the existing bilge) and found a large (1/2”) gap at the bottom of the partion between the gas tank and storage area. After sealing this gap and testing the engine compartment for leakage, I think we’ve solved the water problem. YIPPEE!
I guess I'm confused. Did they find the actual source of the water? Or simply seal off the changing room to prevent the water from flowing back up?
They didn't fill the gap right behind the plug did they?
The plug right in front of the partition that separates the compartment where the fuel tank is located. That recessed plug is designed to let the water from that compartment drain to the bottom of the hull.
Since I wash down my boat after every outing I assume there will be water in the boat so I tilt the trailer after use and most will drain out. Double check the flush port it leaks while underway at high rpm. And all the other areas touched on.
Are you asking about the drain plug in the engine compartment or the drain plug in the bottom of the center console storage area as shown in the picture? I sealed both of the center console storage area plugs and they are in the closed position. The dealer took the plug out of the eng8ne compartment near the gas tank and told me to keep that open at all times. This will allow any water to drain towards the two bilge pumps in the engine compartment.
So it sounds like you're saying there is a drain plug sitting in front of the motor at the floor that allows water to drain from the front of the boat to the rear of the boat. That's pretty common but it's not common to be able to plug that drain I guess I will have to take a look at mine and see if there's one down there but that certainly makes sense that should always be open
The back plug in the changing room under the console is designed to let water from the gas tank compartment drain to the bottom of the hull.
And where does the water in the bottom of the hull go?
Great find where did you get that schematic from??
Someone posted it on here but I don't remember who.
The extra bilge pump in the engine compartment is always a good idea.
You know, I left a reminder to open that drain plug in the forward wall of the engine compartment but plum forgot for the past year! Just opened it up after reading this and voila, no water came out! I'll leave it open for now.
