NewBoater
- Virginia Beach
- 242X E-Series
I have a 2015 SX 210. When I am cleaning the deck inside the boat or it's raining hard all of the water goes to the back of the boat to the engine compartment area and there is a hole on the floor. Where that water drains from that hole is out a hole on the bottom of the boat. The very underside where there is like a little speedometer wheel and a hole. I think that little black wheel spins and tells the boat how fast it's going. Should water not be coming out of this hole from the deck? There is a tube in the engine compartment that takes it from that hole by engine compartment deck to somewhere I just can't tell where.
Please explain to me how all of this work. I am so confused. Is this a self bailing feature and it is supposed to come out that hole or something is just not sealed right and nothing should come out that hole but instead it should come out when I remove the drain plug?
Does the bilge control that water from the deck and in that tube or only water in engine compartment?
Thanks for any and all help explaining all this.
