Jet pump Venturi
Spolly
Scarab
HO Impulse
so Going back two summers I sucked up a small rock and wiped out my wear ring, I replaced and been having a blast since, however I been snooping around and ordered a solas 13/19 prop, but when when replacing I noticed a few chunks out of the Venturi, @only $70 I think iam replacing but curious if any of the gurus know how much 3 damaged fins would hurt velocity/performance.?
Dean P
Chaparral
VRX
Good to know. Thanks for sharing. Enjoy...
gRobi
Germany erfurt
Scarab
215 ID
I'm very curious, cause there is not much info on Solas in Scarabs. Whanted to change it in my 165HO but found nothing. Even Solas wasn't anble to help me.
Now im thinking of changing the props in my 215HO :winkingthumbsup"
Could you give some more detail? What is your engine, what exactly did you install (part umbers :) ) and it would be perfect if you could explain it's working better a little.
Many thanks :thumbsup:
