Berrie
- Kansas City, MO
- Monterey
- Other
Check your Raw water impeller.
It has a new raw water pump. Also running on a hose, the water pressure tends to easily bypass a worn impeller.
I’m going to run it hot and shoot it with an IR gun for temp readings, and then take the thermostat out and see if that eliminates the problem.
Appreciate the suggestions, thanks guys!
