- Panama City, Fl
- Other
@Mike Byrd pre sale pricing is good until mid September.
Awesome, Bobbie!@JetBoatPilot. So psyched!! Just switched out my fins to tv's from cobra and double checked my wake and it's as good as usual.
Glad to hear that!@JetBoatPilot. So psyched!! Just switched out my fins to tv's from cobra and double checked my wake and it's as good as usual.
Sure. But with a twin you could simply reduce or enclose the outer-facing "opening(s)" and the "Ride" would work like you want it.On a ski it moves in the opposite direction of the input of the bars. So you would have to turn the steering wheel in the opposite direction you are used to. It would totally mess up what you have been taught to do on every boat made
I should not have made the "Ride" reference! Really meant just a pump bucket (Yamaha bucket used with the Ridesystem) modification, would only work in twins.:Help me understand. If you block off the outer openings and when the nozzle is pointed right, the right side pump will have no effect due to the outer outlet being blocked. The water that was intended to exit at that point would become turbulent instead of laminar. I don't think it would be useful. At that point the left side pump would force water out of the right of the gate which would in turn push the boat in the opposite direction the operator intended, which would still produce counter-intuitive reverse control? What am I a leaving out?
I might even forgo deer hunting one weekend to test them out.
